Aug 17th, 2024, 1:11pm
Pages: 1 2
Estimate pk-pJitter using eye diagram in SpectreRF (Read 18257 times)
Re: Estimate pk-pJitter using eye diagram in Spect
Reply #15 - Feb 11th, 2005, 9:35am
Initially you indicated that your oscillator frequency was 2MHz, then you said it was 4MHz. Either way I would not expect you to have a slew rate of 20GV/s. Is this really right? If so, why do you believe 0.5 fs is too small?
Also, did you multiply by sqrt(f0*30us) to convert period jitter into k-cycle jitter?
ic_engr
Reply #16 - Feb 11th, 2005, 9:41am
Ken,
The oscillator frequency is fo=4MHz. what I said was fo/2 = 2MHz.
The oscillator output is a square wave with a rise time from 100mV to 1.1V of 40pSec, therefore, the Slew Rate is indeed 1/40psec=20GV/sec.
No I did not multiply the period jitter by sqrt(fo*30us) yet. The reason I suspect 0.5fSec is too low because the current in each stage of my ring oscillator is very low. Its a low power design and therefore I am not optimisitic that my jitter will that good.
Thx
ic_engr
Reply #17 - Feb 11th, 2005, 5:36pm
It does seem a little too good, but I don't know what else to suggest.
ic_engr
Reply #18 - Feb 12th, 2005, 6:08am
Ken,
I made some modifications to the ring oscillator design. I increased the current and maintained same frequency. When I run standard PSS and Pnoise simulation what I note is that the slope of the Phase noise plot is 30dB/decade upto near the fundamental freq. The fundamental is 4MHz.
The usual fc (1/f noise corner I used to see is now gone.
Can you help me understand what's happened.
Tx
ic_engr
ic_engr
Reply #19 - Feb 12th, 2005, 9:12am
Does this mean that fc doesnot exist in the new design. The slope is all the way -30dB/dec.
Pleas let me know.
ic_engr.
Reply #20 - Feb 13th, 2005, 10:02am
This usually occurs because you set maxsidebands in the pnoise analysis to "0" - whereas it should be a number large enough to include all significant contributions. Setting it to 0 in particular will omit any up-converted flicker noise from DC, so that's often a cause.
ic_engr
Reply #21 - Feb 14th, 2005, 3:23am
I did check the Maxsidebands and it is set to 12. So I am not sure what's happening. The change I did is that I made the bias circuit with a resistor. The slope is all the way -30dB/dec.
Any suggestions will be greatly appreciated.
Thx
ic_engr
Reply #22 - Feb 14th, 2005, 4:52am
You might want to look at the noise contributions. I suspect that your noise may be dominated by the noise from the bias circuitry (I don't think that's necessarily unusual, if there's high gain from the bias circuitry to the output), and since that doesn't have any flicker noise, you don't see the flicker knee.
Can't remember if you're running in ADE - but if you are, use the noise contribution UI (under the results menu) to take a look at which devices contribute the most noise.
ic_engr
Reply #23 - Feb 14th, 2005, 1:32pm
You are right I did check and its due to the resistor. Okay So can I then estimate jitter with the phase noise plot I have or not.
Since the expressions in Ken's paper do mention that the slope should be -20dB/dec and I have -30dB/dec will these be valid to use.
ic_engr
Pages: 1 2
