Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Apr 25
th
, 2024, 10:59pm
Home
Help
Search
Login
Register
PM to admin
Modeling
Behavioral Models
› VerilogA handling for buses
Previous topic
Next topic
VerilogA handling for buses (Read 11891 times)
kapylan_pallo
Mar 29
th
, 2005, 10:02am
I'm admittedly a novice in verilogA and am simply looking to define an input bus in the verilogA language. For example, the verilogA 8-bit ADC in the ahdlLib library has 8 input terminals. How does one convert this to a single 8-bit bus to reduce the terminal count on the symbol?
KP
IP Logged
gsuarez
Re: VerilogA handling for buses
Reply #1 -
Mar 30
th
, 2005, 12:03pm
I'm not an expert in Verilog-A but you can use this as an example,
module FLASH_ADC3bit(vin,vref,clk,dout);
input vin,vref,clk;
output [0:2] dout;
electrical vin,vref,clk;
electrical [0:2] dout;
George
IP Logged
jbdavid
Reply #2 -
Oct 2
nd
, 2005, 6:09pm
NB: MOST people I have worked with have used the
0 bit as the LSB.. (and I like verilog 2001 syntax)
so
module myADC (input vin, clk, output [7:0] D);
electrical vin;
logic clk;
reg D;
always @(posedge clk) begin
// calculate the output code from V(vin);
endmodule.
For examples of a couple of ADC's and DAC's created this way look in the bmslib shipped with the cadence tools..
jbd
jbdavid
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
»» Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
