Apr 28th, 2024, 10:43pm
Assura Problem (Read 2873 times)
Tom
Assura Problem
May 19th, 2005, 2:22am
I have a problem with Assura and I hope  somebody can help me.
My Goal:
Go through a layout and find all places where the distance between two lines (on the same layer) is less than a required minimum.
I want Assura to do this by executing a Design Rule Check for minimum net distances.
My Problem:
Assura delivers a file with rule violations. These are given as GEOMETRICAL information. But I need to know the NAMES of the nets involved. I see two possible approaches:
1.) Assura delivers net names (and hierarchy information) directly
2.) I read the geometric location information delivered by Assura and look in the Cadence Database for nets at these locations.
Naturally, I would like the FIRST approach to succeed because it would be far simpler for me.
Best regards
  Tom
PS: Please excuse my bad english
DReynolds
Scarborough ME
Re: Assura Problem
Reply #1 - May 20th, 2005, 12:25pm
Tom, can you give some more info about what you are doing... where did the layout come from? Virtuoso, virtuosoXL, place and route? Do you have clean LVS and you are doing extraction?
If you don't have clean lvs, where do you want assura to get net names from? If your layout came from a tool that creates def, you could get the info you are looking for to coorelate physical location with nets from that....
David Reynolds
