May 3rd, 2024, 7:07am
Simulating DAC with qpss (Read 2525 times)
ml
May 24th, 2005, 11:47am
I have a multi-bit D/A where the input signal is fed from pwl sources. The D/A is a switched capacitor structure. Would appreciate if somebody can help me run distortion analysis. How does the simulator know about the input tone. Thanks.
Re: Simulating DAC with qpss
Reply #1 - Jun 1st, 2005, 8:44pm
ml,
  Why not just synthesize a sine wave and run an FFT? Use
a sine source and the ideal ADC in the ADE ahdlLib to generate
the digital codes for the D/A Converter. Depending on your
application, the Spectre fourier analysis maybe also be appropriate.
NOTE: the analogLib four component does not support the
            full features of the fourier analysis so you may need
            to do some manual editing.
BTW, an FFT uniformly samples the D/A converter output so it will ignore
the effect glitch impulse on the output response. In some applications, this
effect can not be ignored, in particular, waveform synthesis in
communications systems. Spectre's fourier analysis uses the Fourier
Integral and inegrates over the entire waveform so it will include the
effect of glitch impulse, see Ken's book for more details.
