May 2nd, 2024, 11:36pm
DAC clock jitter (Read 5979 times)
Visjnoe
Guest
DAC clock jitter
Jun 04th, 2005, 8:09am
I'm currently investigating (@ the architectural level) a 12b delta-sigma (oversampling) CMOS DAC.
One of the main non-idealities associated with CMOS ADCs/ DACs is the clock jitter.
Modeling of clock jitter for ADCs is fairly straightforward: one just assumes 'ideal clock instants' but adds a certain deviation dv to the 'ideal sampled values'. Afterwards, FFT processing of the data shows the effect of the clock jitter.
However, for a DAC, i can't come up with a way to model the clock jitter...of course, generating a clock with jitter is not the problem, but data that is generated in such a way can not be used for FFT processing (requires equidistant points).
Does anyone have an idea and/or experience with modeling of clock jitter effects on DAC performance?
Thanks a lot!
Peter
  IP Logged
Re: DAC clock jitter
Reply #1 - Jun 4th, 2005, 8:46am
If you have access to Spectre you can use it. It provides two ways of performing a Fourier analysis. The FFT, built into Artist, is a discrete-time Fourier transform. The Fourier component, built into Spectre itself, computes the true Fourier integral, and so is a continuous-time Fourier transform. It will accurately catch the jitter.
Visjnoe
Guest
Reply #2 - Jun 6th, 2005, 5:11am
Does anyone know an alternative to using the continous FFT (requiring SpectreRF)?
Greetings
Peter
  IP Logged
Reply #3 - Jun 6th, 2005, 8:07am
Visjnoe,
  Ken described Spectre's Fourier Analysis. This analysis
is a basic capability of Spectre and does not require a
SpectreRF license.  However, the fourier element
implemented in analogLib is only a subset of the full
functionality and you should probably run Spectre from
the command line(unless you want to modify the CDF
yourself). BTW, Spectre's Fourier analysis is described
in chapter 5 of Ken's book.
  Also had a question for Ken Smiley , when using the fourier
integral for analyzing oversampling ADC/DAC is there
any method to window the data? Since for oversampling
ADC/DAC the data is not periodic outside the time
selected for the Fourier analysis, it seems like the
data needs to be windowed to prevent spectral leakage.
Reply #4 - Jun 6th, 2005, 9:30am
Sheldon,
    The only way I know to apply a window to the Fourier Integral components in Spectre is to add Verilog-A code between the Fourier component and the rest of the circuit that implements the window.
Peter,
    The only alternative to Spectre's Fourier Integral that I know of is to build a Fourier analyzer directly into your circuit using multipliers, integrators, etc. Each harmonic requires a sine and cosine source, two multipliers, and two gated  integrators. Such an analyzer can be implemented using Verilog-A. You would only want to do this if you were interested in very few harmonics (say no more than 3).
