Jul 16th, 2024, 10:13am
Aborting a simulation thru VerilogA (Read 358 times)
Eugene
Jun 14th, 2005, 11:08am
Does anyone know of a clean VerilogA trick to deliberately halt a Spectre simulation? I would like Spectre to perform the DC, initial transient, or perhaps an AC analysis, check the results, and then abort the remaining analyses if the results fail a user-defined test. I do not want to wait for a long transient analysis only to find that the DC, initial transient, or even the AC analysis indicated a problem. For example, if the DC analysis converges but shows a bias is too low to generate meaningful transient results, I don't want a parametric sweep to waste a day on that data point. I'd rather abort the simulation and move on to the next data point in the sweep. Currently, I am driving a terminal current to 1e20 amps to deliberately crash the simulator under some conditions but that is somewhat clumsy and does not identify which of my tests failed.
Re: Aborting a simulation thru VerilogA
Reply #1 - Jun 14th, 2005, 7:39pm
Eugene,
  Have you looked at SpectreMDL? It was created for
the task of perofrming measurements can control
the simulator.
Reply #2 - Jun 14th, 2005, 9:02pm
There's an enhancement request for doing this:
   PCR: 755453
 Title: Need a way to prematurely terminate an analysis
There currently is an internal task for doing this, but it's not public as it's quite likely to change (it's not part of the LRM).
Eugene
Reply #3 - Jun 15th, 2005, 10:20am
Thanks Sheldon and Andrew for you comments. I will check out SpectreMDL.
John O Donovan
San Jose, CA
Reply #4 - Jun 16th, 2005, 1:58pm
SpectreMDL probably won't help you either. It cannot really
alter the control flow as you wish here. It can stop a specific
transient prematurely when all measurements are complete
for that analysis, but you cannot conditionally run another
analysis based upon the result of a prior analysis, (ignoring
a search/optimization type loop).
Other than using Verilog-A, maybe the cleanest approach
would be to use the 'assert' statement to create your tests.
Then if the assert fails, it could exit without running any more
analyses. In the following example, you can define a
set of asserts, which generate an error upon failure. These
are then disabled for the following transient analysis. If
the assert(s) fail, the dc analysis will error out and then the
transient will not run. If they succeed, the transient will run
as expected.
// Define you assertions
assert1 assert dev=v1 param=i min=-25m level=error
// Run the DC
dc1 dc
// Disable the asserts for the transient analysis.
disableasserts checklimit disable=[ "assert1" ]
tran1 tran stop=1u
 John
Reply #5 - Jun 16th, 2005, 5:17pm
Eugene,
  Since you are writing a Verilog-A model anyway, wouldn't
writing an OCEAN script file be easier? Since the transient
analysis does not need to be run with the dc and ac
analysis. Why not do two runs, for example, you might run
the dc and ac analysis, do the measurements, then
generate a file to run the transient analysis.  It would not
be entirely automatic but it would give you insight into
the transient analysis run time before the simulation
starts.
  Never created runs files from an OCEAN script, but I have
written OCEAN scripts that automatically generate data
sheets, the principle is the same.
Eugene
Reply #6 - Jun 16th, 2005, 11:01pm
John,
Thanks for the code. I will check it out.
Sheldon,
Thanks for the Ocean suggestion. However, my brief experience with Ocean is that it is fairly cryptic. Nevertheless, it may be time to check Ocean out too.
Thanks again guys.
Eugene
Reply #7 - Jun 17th, 2005, 6:50pm
In looking through the Cadence on-line documentation for something else I stumbled across the $finish command. I tried it and it appears to do exactly what I want.
There is also a $stop function that lets you resume simulation.
OOPs! It seems I jumped the gun. The $finish works for one run but not with the Parametric Tool. If I sweep a parameter that should invoke the $finish statement on the first run, all subsequent parametric runs terminate too, even if a single separate run at those parameter values runs successfully. Guess I'll try MDL or Ocean.
Reply #8 - Jun 17th, 2005, 11:14pm
Hi Eugene,
Yes, it ($stop, $finish) completely kills the simulator at the moment. We have a PCR on this to either fix that, or provide an alternative function to finish just that analysis  ;)
manyoki
Humble is not
stupid.
suburb
Reply #9 - Oct 14th, 2005, 2:39pm
i used $stop successfully during parametric sweeps to cut down sim time once a condition was satisfied.
for example, the following simple code makes the simulator stop the current run when sigp-sign has a positive zero crossing:
`include "discipline.h"
`include "constants.h"
module stopflag(sigp,sign);
input sigp, sign;
electrical sigp, sign;
  analog begin
     @ (cross( V(sigp) - V(sign), +1 ))
        $stop;
Zoltan
