May 18th, 2024, 11:16am
problem for big circuit extraction (Read 4856 times)
lily
seattle
Jul 27th, 2005, 1:17pm
I am trying to extract a very big layout using Cadence diva extract. And I got the "insufficient memory" problem. I even tried to modify the divaEXT.rul to ignore those RCs, but still cannot get it passed.  :(
My system already got 16GB M+13 GB virtual M. Is there any option in the tool for less memory consumption? or any better way that I can try to extract this circuit?
Thanks a lot!
Paul
Switzerland
Re: problem for big circuit extraction
Reply #1 - Jul 28th, 2005, 12:31am
Hi Lily,
try google for
comp.cad.cadence +"diva" +"large circuits"
Although you don't specify the size of your design, these posts are quite explicit, Diva is probably not the right tool for full-chip extraction. Do you have Assura or Dracula available for such a job?
Paul
lily
seattle
Reply #2 - Jul 28th, 2005, 3:54pm
Hi Paul,
Thanks for your reply! We only got the divaEXT.rul from the PDK. We do have Assura but I don't know how to use it if we just have the diva rule file.
Paul
Switzerland
Reply #3 - Jul 29th, 2005, 2:32am
Lily,
Assura is able to work with Diva rules (it may require some modifications though, I think). However, I never tried it. Have a look at the Diva to Assura Migration Guide in the Assura installation documentation.
Good Luck
Paul
lily
seattle
Reply #4 - Jul 29th, 2005, 1:05pm
Hi Paul,
Thank you so much! I will look at it.
lily
