May 1st, 2024, 7:40pm
what could make an integrator? (Read 4501 times)
trond
Glasgow, Scotland
Aug 07th, 2005, 1:18am
I was wondering what circuits might act as a continuous time integrator? I do not mean obvious circuits like RC Integrators Smiley.
For example, we all know a VCO can be modelled as 1/s. An integrated accelerometer was pointed out to me as well.
I am curious what people have come across.
Thanks for any feedback.
Re: what could make an integrator?
Reply #1 - Aug 22nd, 2005, 5:32am
If you're integrating something, you need a state variable to keep track of the result, don't you?  This means either a capacitor (charge as the state) or an inductor (current as the state).  I guess with MEMS you can integrate to get velocity or position.  If you are doing microfluidics, you can integrate to get total fluid volume.  But if you're really interested in *circuits*, you're pretty much stuck with capacitors and inductors.
trond
Glasgow, Scotland
Reply #2 - Aug 22nd, 2005, 7:57am
Thanks for your feedback.
So far the only other thing I have come accross (which is still a circuit, sort of) is a magnetic sensor. There I suppose a magnetometer senses a magnetic field by means of the current it induces in a coil. A voltage is generated which proportional to the rate of change of the flux.
So emf=-d(phi)/dt,  an integrator. Yay.
jbdavid
Reply #3 - Sep 20th, 2005, 10:47am
Doesn't EVERY conservative system have an integrator? 8)
Position is integral of velocity..
Velocity is integral of force/mass
same with the angular systems..
In plumbing a resevoir (my RO system has one with an air pressure bladder under my sink.. )
Maybe I should write a verilog-A model of that system?
Cheesy
In Solid-State systems.. The Capacitor has been the fundamental (analog) integrator.. as Inductors are harder to design well in silicon..
with Mems - you could use position and a spring to store
the energy..
Jonathan
jbdavid
