It sounds as if you're running an old version of Assura. There was a problem where some of the Assura files were not platform independent (due to byte order issues), and running on Linux with cap_coeff.dat generated on Sun would give this message.
According to my searches, it was fixed in Assura 3.0.6 (assura 3.0.X is no longer supported, BTW) - but even then, if the cap_coeff.dat had been generated on Linux, it would need recreating.
You don't give any clues as to the version of Assura being used - so I can't be more specific.
