May 18th, 2024, 8:17am
ASSURA  crashes (Read 61 times)
rmukh
ASSURA  crashes
Sep 07th, 2005, 11:18pm
I am running ASSURA 50 extraction on ACE50 platform. My layout is drawn on Virtuoso Layout editor. DRC and LVS runs properly but RCX exits after doing lots of calculations. I have reproduced the relevant portion of the log below. Can anyone help please ?
# Run pax16 to generate capfile
pax16 -V -scf sip.cmd -filterfile maxnetfile -dC \
     cpoly_poly_CPP_floating_poly_capacitor_psub_CAP_1052.cap,poly_field_CAPA_accumul
ation_capacitor_CAP_1086.cap:warn \
     -M_perim_off -c \
     /export/students/rmukh/work/analog/cmos9/RCXRunData/5lm/cap_coeff.dat \
     -f field:field_cut comp:comp_cut poly:poly_cut cpoly:cpoly_cut \
     metal1:metal1_cut metal2:metal2_cut metal3:metal3_cut \
     metal4:metal4_cut metal5:metal5_cut gate - \
     /export/students/rmukh/work/analog/cmos9/RCXRunData/5lm/paxfile_coeff \
     - - NET - tmp_capfile
*WARNING* at "pax16": fatal: -c option is now modified to accept only
*WARNING* at "pax16":      shared objects of type <filename>.so. Refer to man
*FATAL* at "pax16":  page on how to build a <filename>.so on your platform
*WARNING* Bad return status from RCX run. 0x1
Re: ASSURA  crashes
Reply #1 - Sep 8th, 2005, 3:17pm
It sounds as if you're running an old version of Assura. There was a problem where some of the Assura files were not platform independent (due to byte order issues), and running on Linux with cap_coeff.dat generated on Sun would give this message.
According to my searches, it was fixed in Assura 3.0.6 (assura 3.0.X is no longer supported, BTW) - but even then, if the cap_coeff.dat had been generated on Linux, it would need recreating.
You don't give any clues as to the version of Assura being used - so I can't be more specific.
