atul
thanks paul for reply. i could not do the complete simulation as it showed the errors, the error message:
Internal error found in spectre during periodic steady state analysis `pss'. Please run `getSpectreFiles' or send the netlist, the spectre log file, the behavioral model files, and any other information that can help identify the problem to support@cadence.com. Assertion failed in file `devices.c' at line 4587. Assertion failed. i could not able to locate the devices.c or run the getSpectreFiles. my circuit is right, i mean it is very basic circuit to design a switched cap filter. i am not sure about the clock. i am using primlibRF library components
About the resistor, i am using poly2RF resistor available in primlibRF library, i could not able to change the value i want 10 kilo ohm, i can't, it can change max. to 5 kilo ohm, so i am adding the 2 resistor in series. But this is very simple circuit, for large circuit it will be very difficult.
paul one more thing do you know where i can get the schematic of switched capacitor filter which is implemented in cadence.
again thanks for replied,
