May 19th, 2024, 12:47am
Switched Cap. filter (Read 4189 times)
atul
Sep 25th, 2005, 1:25pm
i am designing a switch capacitor filter which is used in GSM technology by using spectreRF available in Cadence 5.3 version
first step
i have learned how to do simulation of spectreRF.
Second step
i have designed a simple low pass passive filter and replaced the resistance by capacitance and 2 nmos driven by clock.
problem
i couldnot make clocks i  used 2 vpulses sources having max and min. voltages are opposites to avoid overlapping.
this is not proper can anyone please tell me how to design a clock for switched capa. filter or is it available in library of cadence.
also i could not able to change the resistance value.
please help me, VERY URGENT
Paul
Switzerland
Re: Switched Cap. filter
Reply #1 - Sep 25th, 2005, 2:20pm
Hi Atul
[quote author=atul  link=1127679919/0#0 date=1127679919]
this is not proper can anyone please tell me how to design a clock for switched capa. filter or is it available in library of cadence. [/quote]
If you explain what doesn't work it would be easier to help. Maybe you can post the definitions of the sources from the netlist. You can use vpulse sources to generate your clocks, provided you define the parameters correctly.
What do you mean by this? Did you try to change the capacitor value/frequency?
Paul
atul
Reply #2 - Sep 25th, 2005, 3:02pm
thanks paul for reply.
i could not do the  complete simulation as it showed the errors, the error message:
Internal error found in spectre during periodic steady state analysis `pss'.
       Please run `getSpectreFiles' or send the netlist, the spectre log file,
       the behavioral model files, and any other information that can help
       identify the problem to support@cadence.com.
   Assertion failed in file `devices.c' at line 4587.
   Assertion failed.
i could not able to locate the devices.c  or run the getSpectreFiles.
my circuit is right, i mean it is very basic circuit to design a switched cap filter. i am not sure about the clock.
i am using primlibRF library components
About the resistor,  i am using poly2RF resistor available in primlibRF library, i could not able to change the value i want 10 kilo ohm, i can't, it can change max. to 5 kilo ohm, so i am adding the 2 resistor in series.
But this is very simple circuit, for large circuit it will be very difficult.
paul one more thing do you know where i can get the schematic of switched capacitor filter  which is implemented in cadence.
again thanks for replied,
Paul
Switzerland
Reply #3 - Sep 25th, 2005, 3:18pm
This makes things a little clearer. As I am not a regular user of SpectreRF, I'm not sure to be able to answer your questions. I guess SpectreRF would like to see a single source defining the sampling clock. Try using a VCVS for the second clock signal.
For the resistors, I thought you were talking about the switched cap equivalent resistor. I cannot help on this one.
Paul
Reply #4 - Sep 25th, 2005, 6:49pm
This error message is reporting an "Internal Error", also known as a bug. The file devices.c is part of the source code of Spectre. You should report this problem to Cadence.
Given your unfamiliarity with Spectre, perhaps the problem is due to the way you describe the sources or analysis. Perhaps you can post those sections of the netlist?
