Jul 16th, 2024, 11:53am
Disable timing check in NC-Verilog (Read 812 times)
Oct 09th, 2005, 6:44pm
I need to disable timing check for several instances on running post-layout simulation. The simulator is NC-Verilog.
Does anybody know how to disable timing check (setup time and hold time) for only several instances in NC-Verilog?
Yawei
ekne
Yupp, I'm a viking
San Diego
Re: Disable timing check in NC-Verilog
Reply #1 - Nov 4th, 2005, 9:41pm
Assuming you need to "remove" X propagation  :-/
NC-verilog
+ncnonotifier
still get the timing checks but no x generation due to timing checks.
perhaps together with +ncno_tchk_msg to suppress
the messages.
The +ncnotimingchecks disables all as you probably know.
//BEE
