May 12th, 2024, 3:43am
Inverter delay (Read 2015 times)
digital
Guest
Inverter delay
Oct 29th, 2005, 11:15am
I have designed a simple inverter buffer chain with progressively upsized inverters to drive a large load. But when i put the values into hspice and caluculate the delay, the spice results are always smaller than my hand calculated values. Someone told me that its because of slope mismacth at input and output. Cud anyone plz comment on this issue?
  IP Logged
Re: Inverter delay
Reply #1 - Nov 1st, 2005, 6:25pm
Would you please show more details, such as the calculated delay and the simulation results? Otherwise, you should not expect to get helpful comments. Smiley
