Vivek,
This is a tough question, as you can see there are different thoughts on this topic. Bootstrapping comes from the "let's design a more complex circuit to compensate for the non-idealities" school of thought. Another approach is to make things as "simple as possible to eliminate sources on non-ideality", please see the following paper:
"A 3-V 340-mW 14-b 75-Msample/s CMOS ADC With 85-dB SFDR at Nyquist Input," Wenhua (Will) Yang, Member, IEEE, Dan Kelly, Member, IEEE, Iuri Mehr, Member, IEEE, Mark T. Sayuk, Member, IEEE, and Larry Singer, Member, IEEE
The sample and hold is reduced to a switch and a capacitor to minimize non-idealities. Given your targets the simple is best approach may be an appropriate one. The main constraint of this approach is the common-mode rejection of the op-amp and it should be possible to design an op-amp with good common-mode rejection at 1MHz.
