May 19th, 2024, 5:11pm
Pages: 1 2
Source/drain symmetric in MOSFET model (Read 19034 times)
337see733
Singapore
Re: Source/drain symmetric in MOSFET model
Reply #15 - Jan 25th, 2006, 5:40pm
Quote:
No, I meant that you need vx to go from -1 to +1. You should have vb and vg fixed during the sweep (and run the test at several vg and several vb values). VD should be +vx and VS should be -vx.
Yes, I think i should try to do this. Grin
View Profile gilbertsee   IP Logged
337see733
Singapore
Reply #16 - Feb 6th, 2006, 1:43am
I've include the Vs in everywhere of the equation(codes)...sgh...There is some problem with the transition from vx to -vx...
I assume this is coding problem rather than the equation itself...Because, I checked at a single bias of Vd and Vs or (Vs and Vd interchange), the output current are the same.
337see733
Singapore
Reply #17 - Feb 6th, 2006, 6:58pm
Finally, i did that. But, the answer looks similar to the one i do with the flip-reflect approach!
337see733
Singapore
Reply #18 - Feb 6th, 2006, 10:43pm
Hmm...This is symmetry, right?  ;D
Reply #19 - Feb 7th, 2006, 9:45am
337see733 wrote on Feb 6th, 2006, 6:58pm:
But with the flip-reflect approach, you haven't actually tested anything.  If you want to test that f(x) is an odd function, you can't test it for positive x and then plot it for negative x using the flip-reflect approach.
Your last post looks like you've solved your problem now, though.
337see733
Singapore
Reply #20 - Feb 7th, 2006, 5:23pm
Yes...finally......still testing it to verify.  ;D Thanks a thousands...
Pages: 1 2
