Apr 30th, 2024, 12:09am
VBIC HBT modeling (Read 7775 times)
jiklo
VBIC HBT modeling
May 28th, 2006, 12:15pm
HI,
I'am new here, and new in design. Using a Orcad 9.2.
I'am looking to investigate VBIC model SiGe HBT parameters for my work (bachelor work). The main option of HBT is cutoff frecuency shuold be more than 47 Ghz. So, those parameters i need to use in Pspice model editor. Could you send me.
Thank you.
ACWWong
Oxford, UK
Re: VBIC HBT modeling
Reply #1 - May 29th, 2006, 4:11pm
you might try:
http://www2.fht-esslingen.de/institute/iafgp/neu/VBIC/index.html
You can download some conversion programs for Gummel-Poon to VBIC and vice versa. Also useful are the decriptive documents and the verilogA example.
Reply #2 - May 30th, 2006, 4:20am
There's also a VBIC web page on this site:
http://www.designers-guide.org/VBIC/
It looks to contain the same information as the link in the previous post (FHT-Esslingen).
jiklo
Reply #3 - May 31st, 2006, 7:35am
But these is a Verilog net list. How to take a necessary data from there?
ACWWong
Oxford, UK
Reply #4 - May 31st, 2006, 8:55am
The verilogA code is a behavioural model of VBIC device model written in the verilogA language. You can get the equivalent circuit that is used to model a HBT in VBIC from it and some typical values used for the VBIC parameters and contrast it with the SGP (std GummelPoon) model. But a picture is much better so look at :
http://www.designers-guide.org/VBIC/documents/equivalentCircuit.html
It is not clear what you want to do, but if you are looking for some SGP or VBIC model parameters for actual transistors, they are supplied by IC vendors. But in most cases they will only supply SGP.
You use the conversion programs on the VBIC link to translate model parameters between SGP & VBIC and fiddle with the VBIC extension parameters to see their effect, if that is what you want to do....
peter6g
Reply #5 - Jun 15th, 2010, 9:12am
This webpage no longer exists.  Do you know of any other sites?  Thanks.
Peter
ACWWong wrote on May 29th, 2006, 4:11pm:
you might try:
Reply #6 - Jun 16th, 2010, 5:49am
Did you try this site itself?  Clicking Verilog-AMS in the header bar, then looking under Semiconductor Models, I found:
http://www.designers-guide.org/VBIC/index.html
