May 21st, 2024, 7:56am
digital isolation using Pulse transformer (Read 5127 times)
Lanzones
Gold Coast, Australia
Sep 06th, 2006, 7:30pm
I would like to design a isolation transformer that have 0.5mm physical separation between
areas of windings. This is to comply design to astringent mining safety certification. This will work much more like a digital isolator with
LVDS signal @100MHz as an input. load current will be around ~3.3V/25ohms and the DC offset is around 1.5~2V. Could you help me decide on the right ferrite core and specify what type best way to goaround this even the selection of the wire sizes.
I have tried seen icoupler from analog devices and the ISO from texas instrument but the separation between isolation is <<0.5mm. I ahve also tried using ehternet transformer with 10/100Mbps application but the separation between the primary winding and sencondary have no official document.
Hope you could help me with this... Thanks
Re: digital isolation using Pulse transformer
Reply #1 - Sep 7th, 2006, 8:54am
Have you looked into developing a model for this using Sonnet or another electromagnetic model tool? You can at least get a the EM properties there and put an approximate model into a time domain simulator.
Also, a minor comment - sending digital signals with lots of harmonic content through a transformer results in some "interesting" phase responses, that tear apart the digital characteristics of the input signal.
Lanzones
Reply #2 - Sep 7th, 2006, 2:56pm
could you suggest a magnetic sim tool that I can use? I would be glad to know the materials they use for 10/100Mbps ethernet isolation transformer. Thanks...
Reply #3 - Sep 7th, 2006, 11:31pm
Sonnet if you are willing to pay the price. ASITIC if you want a freebie (google it, it is available as a UC Berkley download.)  There are others from AWR, AnSoft and others.
The results you get there constitute a model, that then needs to be put into a SPICE type simulation tool.
Lanzones
Reply #4 - Sep 8th, 2006, 3:35am
Thanks LE... this forum is great... hope you could give me more view on my next post...
Smiley
