May 18th, 2024, 2:19pm
Error found by spectre during circuit read-in. (Read 927 times)
rajks1982
Moscow, Idaho
Nov 02nd, 2006, 11:13pm
Hello analog design lovers,
Am trying to simulate an inductor circuit. I get this error message while doing so. Any idea why this is happening.
Simulating `raw/inductor' on mercury at 11:08:34 PM, Thur Nov 2, 2006.
   raw/inductor: xl is an instance of an undefined model ind.
spectre terminated prematurely due to fatal error. "
-- Rajeev.
-- Rajeev
bernd
Munich/Germany
Re: Error found by spectre during circuit read-in.
Reply #1 - Nov 3rd, 2006, 2:00am
You have not assigned a model to your inductor.
Look in the properties for the instance if you can find
a field called 'model' you have to fill this out
with the appropriate model name.
Bernd
Just another lonesome cad guy
bernd
Munich/Germany
Reply #2 - Nov 3rd, 2006, 2:45am
My information was wrong.
Correction, this error appears if the model is set,
but you have not assigned a model library where the
simulator can find the model.
If you have a valid inductor model, set this in
the Analog Design Environment under
"Setup -> Model Libraries..."
or use the spectre build in "inductor".
Bernd
rajks1982
Moscow, Idaho
Reply #3 - Nov 3rd, 2006, 1:01pm
Thanks Bernd for a quick response. Am sure that I have the right model path and it is included. Am assuming that it is unable to read those models. I get the same message when I use appropriate models for both spectre ans spectreS. Do I have to also include the file extension? My spectreS models have no extension but the spectre models have a .scs extension. Is this any problem?
-- Rajeev
