May 19th, 2024, 10:53am
Set Parameters with Variables ? (Read 2446 times)
Pinhead
Nov 06th, 2006, 6:43am
Hi Guys,
is there any possibility to set a parameter with a variable ?
I need that for an instantiation of a verilog module in a module, i wanna overwrite the parameters of the instantiated module with a variable.
generate
   genvar x
      for (x=0, x< 8, x=x+1) begin: T
              my_osc #(var1[x]);
endgenerate
Thanks!
Gravity is a myth, earth sucks!
Re: Set Parameters with Variables ?
Reply #1 - Nov 6th, 2006, 12:35pm
Pinhead wrote on Nov 6th, 2006, 6:43am:
No.
Parameters must be set at elaboration time; variables aren't initialized until run time..  You have to find another way to set your parameters, not using a variable.
Pinhead
Reply #2 - Nov 6th, 2006, 11:15pm
Thank you Geoffrey!
