jaqijak
Switzerland
Hi everybody, I had recently a problem that may be a via or pin extraction problem: I get an open circuit when extracting with Assura RCX in "C only" mode but a correct extraction when using "RC" option (although I have correct LVS -and visual- check on the layout).
I use Cadence 5.033, Assura version 5.1.41 with IBM 7WL V1.4.0.4DM design kit.
Did I something wrong, does somebody have any idea about this issue ?
Thanks a lot
Jaqijak
