May 18th, 2024, 1:56am
vias extraction problems (Read 2391 times)
jaqijak
Switzerland
Nov 08th, 2006, 1:02pm
Hi everybody,
I had recently a problem that may be a via or pin extraction problem:
I get an open circuit when extracting with Assura RCX in "C only" mode but a correct extraction when using "RC" option (although I have correct LVS -and visual- check on the layout).
I use Cadence 5.033, Assura version 5.1.41 with IBM 7WL V1.4.0.4DM design kit.
Did I something wrong, does somebody have any idea about this issue ?
Thanks a lot
Jaqijak
Re: vias extraction problems
Reply #1 - Jan 12th, 2007, 6:22am
There's no such Assura version 5.1.41. I do recall seeing something similar to this a while back - you probably should try to use a recent version of Assura (3.1.6 is the latest).
