Jul 21st, 2024, 2:27am
Pages: 1 2
UltraSim simulation failed (Read 4249 times)
bernd
Munich/Germany
Re: UltraSim simulation failed
Reply #15 - Nov 21st, 2006, 2:20am
Because AMS Designer is a so called 'single kernel' or 'single
process' mixed signal simulator. Means there is no coupled
simulation and separate netlisting as used for e.g.the ' old
method' Spectre-Verlog XL simulations.
So ncsim is the only process but it uses the chosen analog solver
method under the hood.
Bernd
Just another lonesome cad guy
Pavel
Lausanne/Switzerland
Reply #16 - Nov 21st, 2006, 3:08am
So, I have no possibility to be sure that UltraSim really run.
I thought that there is some sort of high-level shell "AMS Smulator" that calls
either ncsim (for verilog/VHDL) either UltraSim for transistor-level netlists.
So I hoped to see ncsim and UltraSim sharing CPU, in other words I hoped to see in
prstat list x1 time ncsim, then x2 time UltraSim, etc...
Another question - where can I find some sort of benchmarkig of UltraSim performance
I mean such shema (number of gates/transistors) + such stop time correspond to such simulation time.
Why this question - I hoped that UltraSim is more rapid. Before run the simulation I set the most "rapid" settings.
Regards.
Pavel.
bernd
Munich/Germany
Reply #17 - Nov 21st, 2006, 6:05am
There is an elaborator option which indicates that
the analog solver is UltraSim and which should be
visible in the ncelab log file 'ncelab -amsfastspice',
then trust the tool.
UltraSim Simulator User Guide, Simulation Options, located in
<your_install_dir>/doc/UltraSim_User/UltraSim_User.pdf .
Where <your_install_dir> is the root path to either your DFII or
MMSIM installation tree.
You can set the the simulation options through the Hierarchy Editor,
"View -> Properties".
Bernd
Pavel
Reply #18 - Nov 21st, 2006, 7:14am
Thank you Bernd for assistance
I didn't perfectly understand what you mean.
I choose UltraSim as Analog Solver in AMS Options/Simulator.
What I see in ncelab.lab is:
ncelab: 05.50-s008: (c) Copyright 1995-2005 Cadence Design Systems, Inc.
NETZ0115 ), .RDB( _rd ), .DOUT_en( NETZ5 ), .Drive( drive ), .DIN( din ),
ncelab: *W,CSINFI (../90131BA_DIGITAL/TB_0/schematic/verilog.vams,37|39): implicit wire has no fanin (TB_0.NETZ5).
ncelab: Memory Usage - 29.9M program + 47.1M data = 77.0M total
ncelab: CPU Usage - 1.3s system + 2.8s user = 4.1s total (6.5s, 62.6% cpu)
What means "trust the tool"
As for me, benchmarking means relative estimation of performance.
For my case I would like to know if simulation time is correct for my setup:
My setup is as follows:
1300 gates
250 flip-flops
clock1 13MHz
clock2 32kHz
stop time - 10ms
simulation time - about 3 hours
CPU - 900MHz UltraSparc
UltraSim options - the most rapid
What does MMSIM mean.
Regards.
Pavel.
Pages: 1 2
