Thank you Bernd for assistance
Quote:There is an elaborator option which indicates that
the analog solver is UltraSim and which should be
visible in the ncelab log file 'ncelab -amsfastspice',
then trust the tool.
I didn't perfectly understand what you mean.
I choose UltraSim as Analog Solver in AMS Options/Simulator.
What I see in ncelab.lab is:
ncelab: 05.50-s008: (c) Copyright 1995-2005 Cadence Design Systems, Inc.
NETZ0115 ), .RDB( _rd ), .DOUT_en( NETZ5 ), .Drive( drive ), .DIN( din ),
ncelab: *W,CSINFI (../90131BA_DIGITAL/TB_0/schematic/verilog.vams,37|39): implicit wire has no fanin (TB_0.NETZ5).
ncelab: Memory Usage - 29.9M program + 47.1M data = 77.0M total
ncelab: CPU Usage - 1.3s system + 2.8s user = 4.1s total (6.5s, 62.6% cpu)What means "trust the tool"
As for me, benchmarking means relative estimation of performance.
For my case I would like to know if simulation time is correct for my setup:
My setup is as follows:
1300 gates
250 flip-flops
clock1 13MHz
clock2 32kHz
stop time - 10ms
simulation time - about 3 hours
CPU - 900MHz UltraSparc
UltraSim options - the most rapid
What does MMSIM mean.
Regards.
Pavel.
