giedrius
Lithuania
Hi all, Does anyone know, how correctly write rules for cumulative check? I've followed by divaref.pdf manual 339p. example: ...... ratio = if(diode 0 antenna / if(gate gate 1)) ratio = cumulative + byShape(ratio gate) error(ratio > antenna_limit good msg ratio) ................... , but have got following errors: error: drcAntenna error expression does not allow both net and shape based values. error: error clause ratio must be net based to match the expression.
It seems, that error clause want, that ratio expression will be net based. But by example "ratio = cumulative + byShape(ratio gate)", it is shape based. Where is a point?
Thanks, Giedrius
