May 17th, 2024, 2:30am
Calculating power in Cadence Spectre (Read 5771 times)
sarivisetti
Denton,TX
Nov 21st, 2006, 12:19pm
Hi
I was trying to calculate the power consumed by an instance in cadence spectre using the calculator option. I am able to get the waveform of the power and when i am clicking on the calculator->then click on wave->then take an average-> and click evaluate.....it is giving me a warning
"Evaluation error, Unknown scalar data type: nil". I am able to calculate the average voltages and currents. The problem comes only with power calculations.
Can someone please help me with this.
thanks in advance...
sarivisetti.
bernd
Munich/Germany
Re: Calculating power in Cadence Spectre
Reply #1 - Nov 22nd, 2006, 12:26am
Have you ticked in ADE "Outputs -> Save all ..." and
then "Select power signal to output == all"?
By default the button is disabled.
Bernd
Just another lonesome cad guy
sarivisetti
Denton,TX
Reply #2 - Nov 22nd, 2006, 10:08am
hey,
Thanks for a quick reply.
yes I did save all the powers, like I followed the same procedure before too. But still I am not able to get the power value. its giving me the same warning message.
I really dont know what i am missing to do.
Please help.
Thank you,
Sarivisetti.
ACWWong
Oxford, UK
Reply #3 - Nov 22nd, 2006, 12:28pm
how are you calculating power ? what expressions are putting into the calculator ?
Are you using wavescan or AWD ?
It is much better to express your power as transient current or voltages of nets rather than waveform objects.
But if you can plot say IT("/Rout/PLUS") and VT("/out") and also plot the product, then average should evaluate.
sarivisetti
Denton,TX
Reply #4 - Nov 27th, 2006, 10:21pm
hey,
Thank you for the reply. Yes, I was using the wave scan. I could get the power by taking the product of current and voltage. But was just wondering why the wavescan isn't working..Anyways Thanks a lot again for you reply.
Sarivisetti.
