Hi all!
This topic is related to
http://www.designers-guide.org/Forum/YaBB.pl?num=1167842389/0.
When I tried to simulate the model posted within the previous topic, I achieved an error from AMS Designer's solvability check (see error message below). Nevertheless, I am pretty sure, that the DAE system is solvable. The simulator is probably confused by the "abnormal" formulation of the following equation:
(VD, ID, CJ) == proceqs(VIN, IIN, VOUT, IOUT, VD, ID, CJ, dIDdt, dVDdt) TOLERANCE "Current";
Is there a way to disable the solvability check?
Thanks for your help!
Daniel
-------------------------------------- BEGIN ERROR MESSAGE --------------------------------------------
ncvhdl diode_fulleq_seq.vhd
ncvhdl: 05.83-b001 Engineering Build Dated Fri Sep 8 18:12:42 2006 Generated on amsfarmlnx14.cadence.com: (c) Copyright 1995-2006 Cadence Design Systems, Inc.
ARCHITECTURE dae OF mydiode IS
ncvhdl_p: *E,SCSUMM (diode_fulleq_seq.vhd,24|15): Solvability: Summation Check failed. 5 simultaneous statements found; 7 are required in this architecture.
-------------------------------------- END ERROR MESSAGE --------------------------------------------
