May 18th, 2024, 12:33am
Laser diode verilog-a Model(QWLD ) (Read 13227 times)
micro.duke
Wuhan,P.R.China
Feb 02nd, 2007, 2:25am
Who can wirte a laser diode verilog-a Model?
I have a laser diode source code in pspice format.
Who can convert it to verilog-a or hspice?
help me .
Thanks.
View Profile micro.duke micro.duke   IP Logged
Re: Laser diode verilog-a Model(QWLD )
Reply #1 - Feb 2nd, 2007, 5:04am
It's not that hard, you can probably do it yourself.  How long is the source code?
mg777
Reply #2 - Feb 2nd, 2007, 8:06am
http://www.photonics.ee.ethz.ch/publications/MOT_Lett_Jungo_2003.pdf
is an excellent paper on the subject. It deals with VCSEL's, but the rate equation methodology will work for long cavity lasers as well. In particular note that a fixed integration time step has been used (see Sec. 4). Beam profiles are obtained too, so this is pretty powerful stuff.
M.G.Rajan
www.eecalc.com
micro.duke
Wuhan,P.R.China
Reply #3 - Feb 2nd, 2007, 7:39pm
Thanks.
The source code is not long.I try convert it  to verilog-a or hspice format.But I'm not succeed. Cry
On the other hand. It is a circuit model for qwld.It's not 2D/3D model.I'm not care 2D/3D model.
Because I'm designing a Laser-diode drivers for SDH/SONET System(155Mbps~1250Mbps or 2.5Gbps).So I simulating the drivers with the QWLD Model.
Who Can convert it to verilog-a or hspice format.
Or who make a model for me ?
Thanks.
Reply #4 - Feb 5th, 2007, 5:51am
micro.duke wrote on Feb 2nd, 2007, 7:39pm:
I'm fairly sure I *could* do it, but it would take me a good hour at least, and then I don't have PSpice to verify it ...
Why don't you post your best effort so far, and see if we can help you debug it.
micro.duke
Wuhan,P.R.China
Reply #5 - Feb 5th, 2007, 5:49pm
Thanks a lot.
In first. I do try convert it to hspice format. but somthing(eg. 'func' ,The 'G' device is 2 port device in pspice,But in hspice it is 4 port device. etc.) can not translate it.
About 15 days ago. I known the verilog-a language.So I do not try conver it to verilog-a format.
But I know the language can do it.
If you have interest it.You can download Pspice  simulator & pspice netlist form here:
http://www.ee.tsinghua.edu.cn/~zhangyejin/oeic.rar
(11M sn:123456 site:http://www.ee.tsinghua.edu.cn/~zhangyejin/oeic.htm Maybe you must down 3 dll file form http://www.dll-files.com/)
Thank you very much.
Reply #6 - Feb 6th, 2007, 6:46am
micro.duke wrote on Feb 5th, 2007, 5:49pm:
I'veseen an HSpice example that has
Gdio 5 0 CUR='1e-15*V(5)'
which would be a 2-port device.
micro.duke
Wuhan,P.R.China
Reply #7 - Feb 6th, 2007, 7:59pm
Geoffrey_Coram wrote on Feb 6th, 2007, 6:46am:
So Counld you tell me what's it means?
Quote:
HSPICE/SPICE™ Interface and SPICE™
2G.6 Reference Manual
Product Version 5.1.41
June 2004
Page 85:
Voltage-Controlled Current Sources
General form:
GXXXXXXX N+ N- <POLY(ND)>NC1+NC1- ... P0 <P1 ...> <IC=. .>
Examples:
G1 1 0 5 3 0 0.1M
GR 17 3 17 3 0 1M 1.5M IC=2V
GMLT 23 17 POLY(2) 3 5 1 2 0 1M 17M 3.5U IC=2.5,1.3
N+ and N- are the positive and negative nodes, respectively. Current flow is from the positive
node, through the source, to the negative node. POLY(ND) only has to be specified if the
source is multi-dimensional (one-dimensional is the default). If specified, ND is the number of
dimensions, which must be positive. NC1+, NC1-,. . . are the positive and negative controlling
nodes, respectively. One pair of nodes must be specified for each dimension. P0, P1, P2, . .
., Pn are the polynomial coefficients. The (optional) initial condition is the initial guess at the
value(s) of the controlling voltage(s). If not specified, 0.0 is assumed. The polynomial
specifies the source current as a function of the controlling voltage(s). The second example
above describes a current source with value
I = 1E-3*V(17,3)+1.5E-3*V(17,3)**2)
« Last Edit: Feb 6th, 2007, 9:02pm by micro.duke »
Reply #8 - Feb 7th, 2007, 7:08am
micro.duke wrote on Feb 6th, 2007, 7:59pm:
It's a voltage-dependent current source; the current is supplied across nodes 5 and 0 and has a value given by the expression. My understanding is that you can put any expression of voltages (and currents?) in the CUR='' expression; in this case, the current is 1e-15 * the voltage on 5.  One could also have CUR='1e-15*(exp(V(5,0)/0.026) -1.0)' to get a diode, and I think the V() reference doesn't have to refer to the same nodes that the current is supplied across.
micro.duke
Wuhan,P.R.China
Reply #9 - Feb 8th, 2007, 12:33am
OK.
If you are right.We can simulate the circuit.
Quote:
V01  6 0  1
R1   5 6  10
R2   6 0  1m
.OPTION runlvl=5
.OPTION POST=1
.OPTION POST_VERSION=9601
.OPTION INGOLD=1
.OPTION  ACCURATE=1
.OPTION PROBE
.PROBE I(R1) V(5) V(R1)
.TRAN 1n 2u
.end
But I do it & have no result.  :(
Maybe the circuit is error. Wink
Thanks.
Reply #10 - Feb 8th, 2007, 11:11am
The Gdio current is 1e-15 times the voltage; this is absolutely tiny.  Change it to 1e3 -- or make it a real diode, with an exp().
micro.duke
Wuhan,P.R.China
Reply #11 - Feb 11th, 2007, 8:44pm
OK.
I will try do it.
Thanks.
