May 19th, 2024, 8:47am
strange simulation result (Read 10850 times)
feiyue
Jul 10th, 2007, 10:42am
hi all,
I am designing a voltage-mode switching regulator,it needs a compensation network with 2 zeros and 3 poles.
I simulate the whole regulator without adding the compensation network,simulaiton result is ok.but when the compensation network is added,the
result is weird,it seems that regulaor unstable,error amplifier output also saturate and oscillate between vdd and 0.
I am not sure it is because my unconsiderable setting of initial condition for simulation or it is because the compensation network is unstable.
Any comments and suggestion are greatly appreciated.
feiyue
feiyue
Re: strange simulation result
Reply #1 - Jul 10th, 2007, 3:24pm
nobody could help?  :'(
it is a type 3 error amplifer,I think the component values should be true,but i don't know whether i need to do something for simulation initiation,
i really appreciate if anyone can help!
Eugene
Reply #2 - Jul 10th, 2007, 6:13pm
It would be nice to know what each waveform represents but your "compensated" system indeed looks unstable. I would recommend constructing a state space averaged model and looking at the loop gain with and without the compensation. If your compensator has three poles, it is quite possible for your compensated system to be unstable. How did you design your compensation? i.e. how did you choose the compensation poles and zeros?
feiyue
Reply #3 - Jul 10th, 2007, 7:05pm
Thank you very much,Mr. Eugune!
I design a type 3 error amplifier ,it seems very classical and is described in detail in the book of "switching power supply design".
I choose two pole at the same frequency and is 5 time higher than defined unit-gain bandwidth and two zero at 1/5 unit-gain bandwidth.
I check it using matlab,the phase margin is 60deg. But if i delete the capacitor which is series connected to the integrating resistor R2,then regulator works ok,so i don't know what is the exact problem. is it because the error amplifer without a dc feedback? but i think for a whole regulator,the dc feedback is automatic established.Is it right?
also i don't know whether there are some specific attention i need to pay for the correct simulation.
I don't know how to construct a stata space averaged model.is there any reference?
Eugene
Reply #4 - Jul 11th, 2007, 12:47pm
How did you model the power supply to compute the phase margin?
feiyue
Reply #5 - Jul 12th, 2007, 10:48am
I model the gain of PWM=Dvin/Vramp, gain of resistor string and then gain of error amplifer
check the open loop gain margin and phase margin of the whole system with LC fitler.
Acutally,I found it is the problem of compensation,when i increase the phase margin to almost 90deg,then the systyem work.But when PM=60deg, (calculate at matlab),it doesn't work.
I don't know what is the problem of this.Is it because the model is not correct?
thanks Eugune!
Eugene
Reply #6 - Jul 12th, 2007, 1:52pm
Yes, I strongly suspect an error in the model. Did your brute force simulation include an input filter? If so, did your Matlab model also include the input filter?
feiyue
Reply #7 - Jul 12th, 2007, 4:39pm
do you mean the capacitor in the input battery?
I have not added it and modeling it.
Eugene
Reply #8 - Jul 12th, 2007, 8:44pm
I mean an impedance between the ideal power source and the input to the switch mode power supply.  In space craft power supplies for example, one commonly places a filter between the main power bus and the power supply drawing power from the bus. This is to keep switching noise off the main power bus. Such a filter can destabilize your power supply if it's not designed properly. However, it does not sound like that is your problem. It sounds like you are driving your power supply model from an ideal voltage source.
I'd have to see your model and the circuit you are simulating to be sure but I still suspect your model is not a sufficiently accurate representation of the circuit you are simulating.
hedonist81
Ghost In The Machine
Hyderabad
Reply #9 - Oct 16th, 2007, 8:23pm
Hi Guys
Just joined the forum and saw through the entire discussion. You have 3 poles and 2 zeros. Can you please indicate where each of these occur. Even though you have a good phase margin, it is possible to see and oscillation if there is a pole-zero couplet close by. Such a pole zero couplet gives rise to oscillations.
Also, what is the frequency of oscillations you observe ??
