Jul 16th, 2024, 12:21pm
Transient flicker noise model in Verilog-A (Read 15974 times)
zjuyifeng
Jul 31st, 2007, 2:06am
Does anyone have experience in modeling flicker noise in Verilog-A for use in transient simulations?
I hace to model it .
My simulator is Spectre.
Any ideas would be greatly appreciated.
  Thanks !
Re: Transient flicker noise model in Verilog-A
Reply #1 - Jul 31st, 2007, 9:46am
Verilog-A has a flicker_noise function.
Spectre knows how to do flicker noise for built-in devices for transient noise.
Hence, I would expect that Spectre could also "do the right thing" for flicker_noise() in a Verilog-A model for transient noise.  Otherwise, it's a real nuisance to try to generate time-domain samples of a flicker noise process.  I think there are a couple papers on IEEEXplore.
zjuyifeng
Reply #2 - Jul 31st, 2007, 5:40pm
But I still don't understand what you mean.
flicker_noise() can only be valid in AC simulation. It is not work in transient simulaiton
Please help me more!!!
Reply #3 - Jul 31st, 2007, 6:37pm
Conceptually you would create a Verilog-A current source model that produced a gaussian white sequence at a fixed rate, and feed that into a fracpole with a slope of -0.5. The resulting voltage would have 1/f distribution.
Reply #4 - Aug 1st, 2007, 5:09am
zjuyifeng wrote on Jul 31st, 2007, 5:40pm:
That's not actually true -- it doesn't work in a standard Spice transient analysis, but standard Spice doesn't know anything about transient noise.  The Verilog-AMS LRM should probably have something to say about this.  But my point is: flicker_noise() *does* work in transient noise analysis; try an example and see what you get!
// mynoi.va
module mynoi(a,b);
  inout a,b;
  electrical a,b;
  analog
    I(a,b) <+ V(a,b) + flicker_noise(1000, 1, "flicker");
Put this in a netlist with a current source driving it, run a transient noise analysis.
zjuyifeng
Reply #5 - Aug 1st, 2007, 8:23pm
Thanks for your help.
I had access to the fracpole model.
But when simulated, a error came out.
" PF0 is an instance of an undefined model fracpole  "
Can you help me ?
Reply #6 - Aug 2nd, 2007, 5:55am
Are you using a current version of Spectre?
zjuyifeng
Reply #7 - Aug 2nd, 2007, 6:24am
 The spectre using is the voltage version ?   How to set the spectre for the current version?
Reply #8 - Aug 2nd, 2007, 10:59am
The question is "Are you using a recent version of Spectre?". Both the fracpole and Geoffrey's suggestion require a relatively recent version of Spectre.
To test to see if Spectre supports fracpoles, type "spectre -h fracpole" into a unix command line.
zjuyifeng
Reply #9 - Aug 2nd, 2007, 10:46pm
warning from spectre
    fracpole : no  such component
It's a bad nows for me!!
Reply #10 - Aug 6th, 2007, 6:24am
Did you try flicker_noise() in a time domain noise simulation?  Of course, time domain noise is also a somewhat recent addition to Spectre, and maybe they didn't get the Verilog-A flicker noise implemented in the first go-round, but it does work for me in my version of Spectre (which also has fracpole ...).
