zjuyifeng wrote on Jul 31st, 2007, 5:40pm:flicker_noise() can only be valid in AC simulation. It is not work in transient simulaiton
That's not actually true -- it doesn't work in a standard Spice transient analysis, but standard Spice doesn't know anything about transient noise. The Verilog-AMS LRM should probably have something to say about this. But my point is: flicker_noise() *does* work in transient noise analysis; try an example and see what you get!
Code:// mynoi.va
module mynoi(a,b);
inout a,b;
electrical a,b;
analog
I(a,b) <+ V(a,b) + flicker_noise(1000, 1, "flicker");
Put this in a netlist with a current source driving it, run a transient noise analysis.
