May 6th, 2024, 6:45am
Input-referred noise with pnoise analysis (Read 2282 times)
M.C.
Aug 09th, 2007, 6:42pm
Hi  all,
I've recently been using Spectre, and have been trying to conduct some timedomain pnoise analysis for a comparator I'm designing.  I'm using the iprobe option (with refsideband) to look at the input-referred noise, but when I don't see an option in the results browser that allows me to plot this.  If I use noisetype=source, then I can plot the input-referred noise; however, the results seem to be much larger than one would expect.
Is there a way to use Spectre to calculate the rmsnoise, or do I need to integrate the PSD manually using the calculator?
Thanks for your help.
Re: Input-referred noise with pnoise analysis
Reply #1 - Aug 12th, 2007, 5:11am
MC,
  Does the Calculator rmsNoise function do what you need?
