Berti
I like to use a MOS transistor in accumulation-mode for decoupling of bias voltages. On the left-side of the attached figure, an accumulation-mode varactor is shown as provided by the design-kit I am using. My question is the following: Can I also use a MOS transistor as drawn on the right-side of the figure. Are there any problems? And what is the difference between the two structures (ESR etc.)?
Thank you, Regards
