May 5th, 2024, 11:54am
Accumulation mode capacitor (Read 5201 times)
Berti
Jan 11th, 2008, 8:23am
I like to use a MOS transistor in accumulation-mode for decoupling of bias voltages.
On the left-side of the attached figure, an accumulation-mode varactor is shown as provided by the design-kit
I am using.
My question is the following:
Can I also use a MOS transistor as drawn on the right-side of the figure. Are there any
problems? And what is the difference between the two structures (ESR etc.)?
Thank you, Regards
fran2k5
Re: Accumulation mode capacitor
Reply #1 - Jan 12th, 2008, 7:33am
Hi Berti,
the only difference between the two structures is their C-V characteristics.
While the PMOS-based one has an inversion region for which C=Cox, the other structure (on the left) does not have it.
As far as the gate on the PMOS is higher than its source/drain voltage the accumulation cap is going to work.
fran2k5
Berti
Reply #2 - Jan 12th, 2008, 8:11am
Thank you Frank. You confirm what I have expected.
