Aug 15th, 2024, 1:24pm
The high temperature spice model (Read 668 times)
dandelion
Mar 19th, 2008, 7:36pm
I am designing a circuit which contains a overheat block. The detection thershold is 160'C and if the 160'C is reached, the block will be shutdown.
But I checked the spice model and found the model is only for -40'C-125'C. These is no model descriptions above 125'C. Communicated with the Foundry, they said the above 125 model is not measured.
But for the overheat sub-block, i must simulated it wit 160'C. I wonder is there any risks in it? The actural silicon will be much descranpancy from the design?
Pls. share with your experienc.
Re: The high temperature spice model
Reply #1 - Mar 20th, 2008, 6:22am
I'd suggest you do some plots of all the currents and capacitances as you step the temperature from 100 to 200 in 10-degree steps.  Make sure they look reasonable.
Some models have linear temperature effects, and you might find that eg VSAT becomes negative at 190 degrees, which would be a strong indication that you won't get the right answer at 160.  BSIM4 has VSAT_T = VSAT - AT * (T/Tref - 1);
HdrChopper
Reply #2 - Mar 20th, 2008, 7:10am
Certainly leakage currents will be a headache if not properly modeled. Usually, somewhere between 110 to 130C is where the leakage currents tend to play a role in the total error you get for several analog circuits.
I usually simulate up to 165C and at such temperature a common concern is balancing leakage currents in precision analog circuits.
You might want to consider this too.
Tosei
Keep it simple
