dandelion
Hi, I am designing a circuit which contains a overheat block. The detection thershold is 160'C and if the 160'C is reached, the block will be shutdown.
But I checked the spice model and found the model is only for -40'C-125'C. These is no model descriptions above 125'C. Communicated with the Foundry, they said the above 125 model is not measured.
But for the overheat sub-block, i must simulated it wit 160'C. I wonder is there any risks in it? The actural silicon will be much descranpancy from the design?
Pls. share with your experienc. Thanks
