May 17th, 2024, 11:02pm
Problem in  RF IC Package Modeler Form (Read 2216 times)
AnalogAroma
Jul 31st, 2008, 3:45am
Hi Everybody,
         I need to draw the bond plan showing  the connections  beetween the IC package pins  and chip-bondpads. So, I am using RF IC  Package Modeler (PKG ).
          While using this tool , I have noticed that the upper four  side buttons are active in the opening form. But , the lower four buttons including " Internal lead frame setup " and  "Macromodel Generation " remain inactive always. Even though,  I have given inputs for the upper four features, the lower four buttons still remain disabled.
           Is there any way to activate those lower four buttons ? Any workaround ?
With Regards,
           IKB
Re: Problem in  RF IC Package Modeler Form
Reply #1 - Jan 3rd, 2009, 3:36pm
That doesn't happen for me. Perhaps it's a peculiarity of the options you've chosen for the earlier steps in the flow.
However I should point out that PKG has been end-of-lifed for some considerable time, and no work has been done on it for several years.
