May 18th, 2024, 11:47pm
Jitter In CTDSM (Read 6042 times)
Asmodeus
Jitter In CTDSM
Aug 13th, 2008, 10:33pm
Hello friends, Its realy great to find a good site for analog designers !!  :)
Well, i am working on CTDSM, and was trying to make sure that my CTDSM will nt be degraded enough by jitter.
For that right now, i am using SIMULINK. The problem is that to model the jittery clock, i need to generate pink noise (1/f) noise. and i am unable to generate it in MATLAB or SIMULINK. If anybody has already worked on it. Please help me out !! Smiley
Thanks !!
~VJ~
View Profile Asmodeus   IP Logged
HdrChopper
Re: Jitter In CTDSM
Reply #1 - Aug 14th, 2008, 6:40pm
Have you tried integrating white noise? That should be simple to do.
Tosei
Keep it simple
vivkr
Re: Jitter In CTDSM
Reply #2 - Aug 14th, 2008, 10:59pm
HdrChopper wrote on Aug 14th, 2008, 6:40pm:
Tosei
Hi Tosei,
Be careful !!! Integrating white noise does not give 1/f noise. It gives 1/f^2 noise. However, I think this post is in the wrong forum. It ought to be in the behavioral modelling forum. I remember having seen some discussion long ago on generating pink noise there, but can't find the thread.
Vivek
Re: Jitter In CTDSM
Reply #3 - Aug 14th, 2008, 11:40pm
You can use a fracpole to generate flicker noise. Just drive a fracpole with white noise and it will color it pink. Spectre has a fracpole built in. Or you can use the FracPole suite on http://www.designers-guide.org/Modeling/.
HdrChopper
Re: Jitter In CTDSM
Reply #4 - Aug 15th, 2008, 7:53pm
vivkr wrote on Aug 14th, 2008, 10:59pm:
Hi Vivek,
I think you are right. My mistake. Thanks for clarifying.
Tosei
Keep it simple
Re: Jitter In CTDSM
Reply #5 - Sep 6th, 2008, 6:36am
Hi viks_iisc,
If you use simulink, there is a toolbox named SDtoolbox. SDtoolbox is developed by A. Fornasari, P. Malcovati and available at http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=7589&ob....
It has simulink model for jittered sinewave and colored noise. It is easy to use although I don't understand the algorithm. Smiley
Furthermore, I don't think you need to generate pink noise (1/f) for modeling the jittered clock. Perhaps it is good enough to assume a gaussian distribution random jittered clock.
Best regards,
Yawei
HdrChopper
Re: Jitter In CTDSM
Reply #6 - Sep 7th, 2008, 5:44pm
ywguo wrote on Sep 6th, 2008, 6:36am:
Hi Yawei,
Correct me if I´m wrong but I think that 1/f noise can also be gaussian distributed, so both features are not necessarily contradictory.
Tosei
Keep it simple
Re: Jitter In CTDSM
Reply #7 - Sep 9th, 2008, 2:56am
Hi Tosei,
You put forward a good question. Intuitively, I thought 1/f noise is not Gaussian distributed. However, it has not solid base and proper reasoning. So I agree with you now. It is possible to generate a 1/f noise whose amplitude is Gaussian distributed.
Thank you.
Yawei
