May 1st, 2024, 1:59am
Rx+ baseband filter and VGA overall voltage gain simulation? (Read 2032 times)
wccheng
Aug 30th, 2008, 8:01am
Dear all,
I have a Rx chain (included LNA+mix1+mix2) + baseband filter and VGA. I have combined all together and run the PSS + PXF in order to get the overall voltage gain. However, the simulation result is strange to me. It gives the M-shape voltgae gain and the voltage different is 10dB. However, the voltage gain flatness of Rx chain is within 1.5dB. The gain flatness of baseband filter+VGA is within 1dB. Why the voltage different for overall chain is 10dB and give the M-shape curve? Is there any special setting for this kind of the system? If yes, could you teach me the simulatino setting using SpectreRF?
Re: Rx+ baseband filter and VGA overall voltage gain simulation?
Reply #1 - Sep 4th, 2008, 10:57pm
wccheng wrote on Aug 30th, 2008, 8:01am:
What is a value of local frequency for mix1 and mix2 ?
Just does it show gain including image response of mixer ?
Do you evaluate this using PSS/PXF with same simulation condition as total combination ?
Although you see gain including image response in total combination, you don't see image response in Rx chain ?
« Last Edit: Sep 5th, 2008, 10:34pm by pancho_hideboo »
