Apr 26th, 2024, 11:21pm
use frequency as variable in SP simulation (Read 2568 times)
Ian
Nov 20th, 2008, 7:14am
Dear all,
I'm simulating a transmission line with the model (e.g., the series resistance) only valid at a specified frequency. When I wanna do a swept frequency simulation (e.g., SP), I need to vary the frequency in the model as well. The question is how to access the 'frequency' variable in SP simulation?
Actually I met similar problem before when I want to specify the frequency dependent series resistance for the lossy inductor (i.e., 2*pi*freq*L/Q) in the SP simulation.
Any tips? Thanks.
Ian
Re: use frequency as variable in SP simulation
Reply #1 - Nov 20th, 2008, 3:45pm
Ian wrote on Nov 20th, 2008, 7:14am:
What simulator do you intend to use ?
If you use Agilent ADS engine in RFDE or ADS native, you can use 'frequency' variable directly
in any analyses such as ac, sp, hb, envlp and tran. But you have to pay attention to causality issue for envlp and transient analysis.
If you use Cadence Spectre, you can not use 'frequency' variable even in small signal analyses such as ac, xf, sp and noise.
As workaround in Cadence Spectre, write frequency table of Y/Z parameters then use nport.
http://www.designers-guide.org/Forum/YaBB.pl?num=1225399560/0#3
« Last Edit: Nov 21st, 2008, 2:12am by pancho_hideboo »
Ian
Reply #2 - Nov 21st, 2008, 4:45am
Thanks, pancho_hideboo.
Unfortunately, I'm using Cadence SpectreRF. Seems I have to do single frequency point simulation for now.
Ian
Reply #3 - Nov 22nd, 2008, 4:46am
Ian,
  Could you work around the issue by creating some variable,
voltage/current, proportional to the frequency? It would require
adding an additional terminal to your model in order to sense
the variable and modifying the model to replace frequency with
the variable, see the attached example. I have used this trick
when I needed to know the frequency in order to calculate
inductance, Q, ... from s-parameters. If your model is written
in Verilog-A, you could probably include the calculation in the
model.
Reply #4 - Nov 22nd, 2008, 5:28am
As another essential problem in Cadence Spectre, we can not define Z(omega)=R(omega)+j*X(omega).
In Agilent ADS simulator on RFDE or ADS native, we can write such complex impedance using "freq" variable directly.
There is no method to define complex impedance in Verilog-A.
« Last Edit: Nov 22nd, 2008, 7:31am by pancho_hideboo »
Peruzzi
Reply #5 - Nov 22nd, 2008, 10:07am
pancho_hideboo wrote on Nov 22nd, 2008, 5:28am:
... we can not define Z(omega)=R(omega)+j*X(omega).
In Verilog-A you can express the complex impedance in terms of differential or integral equations for current and voltage.  Would this be okay for your application?
Best regards,
Bob Peruzzi
Reply #6 - Nov 22nd, 2008, 7:29pm
Peruzzi wrote on Nov 22nd, 2008, 10:07am:
Verilog-A is oriented to time-domain simulator and time-domain expression although it can work in small signal analyses such as AC, XF, SP and Noise.
There are still many bugs in Verilog-A for small-signal analyses.
If X(omega) are expressed as combinations of k*(omega**n) and k/(omega**n),
we can write j*X(omega) by using differential and integral equations. This is time-domain expression.
But for more generic X(omega), how to define or write using Verilog-A ? Here we need frequency-domain expession ability.
Such generic X(omega) naturally appear in microwave theory.
Only one frequency-domain expression in Verilog-A is rational Laplace expression. But this is equivalent to time-domain expression of differential and integral equations. For very limited style of X(omega), we can use frac-pole.
I have ADSsim on RFDE where frequency domain expressions are available, so I don't have to insist on using Cadence Spectre which require different tricky methods for each problem.
« Last Edit: Nov 23rd, 2008, 6:27am by pancho_hideboo »
jbdavid
Reply #7 - Dec 18th, 2008, 8:06pm
Those complex values are either Small signal quantities or  Base-band equivalent values..
these are useful in RF systems analysis, so you should put that part of your design in an RF system simulator like ADS  or matlab, and link that to the actual circuit (specified in a model valid for both large and small signals) running in spectre.
RFDE allows Spectre/ADS/Ptolemy co-simulations, and the simulink interface allows spectre&simulink to work together.
Of course this has been a request for years and years.. and probably NOT something solved in a spice-type simulator any time soon.
Jbd
jbdavid
Reply #8 - Dec 18th, 2008, 10:49pm
jbdavid wrote on Dec 18th, 2008, 8:06pm:
No, you are misunderstanding.
I don't mention equivalent lowpass model which is called as baseband model in Cadence where only complex envelope I(t)+j*Q(t) are concerned.
And both Ptolemy and Simulink are time domain simulator in signal flow model(not energy conservative system), although they can treat s-parameter box as complex coefficient FIR model.
I'm mentioning about Analog RF simulation of wireless or high speed wired application in full transistor level circuits.
Also a start of this thread is regarding small signal analyses such as AC, XF, SP and NOISE.
At least, a convolution of Agilent ADSsim is superior than Cadence Spectre as a spice-type simulator.
And feature of convolution of Agilent ADSsim is that it is not restricted to NPORT.
Cadence has insisted on rational fitting(linear macro model fitting) about s-parameter in transient analysis
and denied convolution for long long time.
But recently, Cadence recommend user to use convolution and don't recommend rational fitting.
Rather Cadence is denying rational fitting now.
http://www.designers-guide.org/Forum/YaBB.pl?num=1174585355/1#1
« Last Edit: Dec 19th, 2008, 6:12am by pancho_hideboo »
