May 4th, 2024, 12:48am
Front end simulation (Read 12762 times)
YYou
Nov 25th, 2008, 7:05pm
I am trying to simulate the front-end, which includes LNA, mixer, OSCILLATOR and LO buffer. Just wonder whether it is possible to get the gain, NF and IIP3 using PSS/PAC/Pnoise.
The spectreRF manual has the example using a port/vsin for the LO, but if the port is replaced with an LC oscillator, how to set it up ?
Yyou
Re: Front end simulation
Reply #1 - Nov 25th, 2008, 7:45pm
YYou wrote on Nov 25th, 2008, 7:05pm:
Set up PSS as oscillator analysis.
But for Pnoise you have to observe frequency of output of mixer.
Reply #2 - Nov 29th, 2008, 10:48pm
Sorry, I mistook in my post.
Cadence Spectre can't provide simulations you want to do.
You can simulate gain and NF by using Cadence Spectre.
But Cadence Spectre can't provide IIP3 simulation when local signal is autonomous.
Since you want to evaluate IIP3, at least two large tones are involved in simulation where one is autonomous local signal and the other is RF input signal.
For PSS, a common diviser can't exist between autonomous local signal frequency and RF input signal frequency. So you can't use PSS.
For QPSS, Cadence Spectre don't support autonomous QPSS.
You have to use other simulator such as Agilent ADSsim or GoldenGate.
Agilent ADSsim and GoldenGate support autonoumos multitone HB analysis.
« Last Edit: Nov 30th, 2008, 4:02am by pancho_hideboo »
laixl
San Jose
Reply #3 - Dec 1st, 2008, 11:43am
Spectre will support the autonomous QPSS ( and corresponding small signal analyses, like PAC, PXF, Pnoise, etc ) in MMSIM7.1. You can specify a guess frquency for the LO in the GUI, it is very much like what you do for the autonomous PSS simulation.
Reply #4 - Dec 1st, 2008, 4:05pm
laixl wrote on Dec 1st, 2008, 11:43am:
After long long time since SpectreRF was first released, at last Cadence SpectreRF will be able to have all basic RF analyses which other RF simulators already have.
But issues of Cadence HB-QPSS performance still remains.
Cadence HB-PSS which have only one fundamental is enough comparable to Agilent HB analysis of ADSsim or GoldenGate regarding speed and memory consumption.
Cadence HB-QPSS which have two fundamentals is not so bad compared to Agilent HB analysis of ADSsim or GoldenGate.
But simulation speed is little slow compared to Agilent HB analysis.
Cadence HB-QPSS which have more than three fundamentals is very inferior to Agilent HB analysis of ADSsim or GoldenGate.
Simulation speed is very slow and memory consumption is huge compared to Agilent HB analysis.
I've evaluated HB analysis in SpectreRF using 6.0USR1, 6.0USR2, 6.1, 6.2 versions.
When I come to be able to use MMSIM7.1, I will do performance tests of Cadence Spectre HB-QPSS again including autonomous QPSS.
mustangyhz
china
Reply #5 - Dec 3rd, 2008, 5:19pm
YYou:
I have the same problem. I want to simulation a RF front end. The ADS has the example using a p1_tone for the LO, but if the port is replaced with an real LC oscillator, how to set HB up ? Do you solve this problem in spectre?
mustangyhz
View Profile mustangyhz 3241568   IP Logged
Reply #6 - Dec 3rd, 2008, 8:26pm
mustangyhz wrote on Dec 3rd, 2008, 5:19pm:
YYou:
Unless you evaluate IP3, you can simulate NF and Gain using autonomous PSS(Shooting Newton or HB)/PAC/Pnoise in Cadence Spectre.
Procedure is same as one tone autnomous HB-SS in Agilent ADS.
Here SS means Smal Signal Analysis subjected to Master HB analysis.
SS is same as PAC or QPAC in Cadence Spectre.
If you use ADSsim, you can evaluate IP3 by two tones autonomous HB-SS or  three tones autonomous HB(without SS) analysis.
Reply #7 - Jan 3rd, 2009, 2:55pm
Pancho Hideboo's comments on performance of SpectreRF don't quite seem in line with what is seen in reality - perhaps from not using recent enough versions, or perhaps due to some peculiarity of his circuits/models/etc - this is not what other customers report in general (of course, there are always specific cases which are faster in any one simulator).
Anyway, there is also another way of measuring the IP3 of the system in the question, which is to use the Rapid IP3 method, which uses perturbation methods to allow IP3 to be measured with just PSS (autonomous in this case) of the LO frequency.
Andrew (in case I get accused of bias, I work for Cadence...)
Reply #8 - Jan 5th, 2009, 11:57pm
Andrew Beckett wrote on Jan 3rd, 2009, 2:55pm:
I use @(#)$CDS: spectre  version 6.2.0 09/19/2007 13:58 (usimlx112) $.
I don't think so.
In my environment, I can easily change analysis engines such as ADSsim, GoldenGate and Spectre for completely same schematic view.
But due to lack of Agilent licenses, I often have to use Cadence Spectre reluctantly. When I can get Agilent licenses, I resimulate same circuit using Agilent Simulator since I don't believe Cadence Spectre's results. Then I always feel Cadence Spectre is still very slow and consume huge memory.
I have heard this phrases repeatedly since the days when Cadence Spectre have only shooting newton.
Maybe you are contacting with only EDA Tools Guys and don't hear raw voice of actual designer.
As far as our local Cadence sales, this is true.
Reply #9 - Jan 6th, 2009, 2:09am
Well, your version of spectre is 15 months old, which could contribute. There have been a number of improvements made in recent versions (for example MMSIM 7.0.1 and the upcoming MMSIM71 version) which will improve convergence in difficult situations, and also improve speed, particularly with sweeps. tstab=0 is now the default.
Also, there may be differences in the use model between the simulators, even if you can easily switch between them - you may well be aware of these, but I sometimes see comparisons made when the simulation is not correctly set up - all simulators are different (the classic example is in a multi-tone simulation, not setting the frequency name on sources with the same frequency to be the same, so they get counted independently).
I speak to designers all the time - . I do hear negative feedback as well as positive feedback. I'm an AE, not a sales guy, so speaking to designers (either during training sessions I give, or during on-site visits to debug particular problems) is something that is part of my job.
If you're struggling with SpectreRF, can you work with your local AEs to feedback problems, find solutions, and help Cadence improve the tool? Posting negative comments in this forum is not going to get anything fixed...
imd1
Reply #10 - Jan 6th, 2009, 4:43am
Andrew Beckett wrote on Jan 6th, 2009, 2:09am:
I actually like very much pancho's comments and to see this discussion out in an open forum. I use another simulator for RF, and unless we discover it ourselves we get no warning of potentially serious bugs or shortcomings of the tool.
If I want to know all the good things about it I just have to call and say we'd like to order more licenses/features/products, the sales guy is knocking at my office next morning.
If every one of us light a little fire under their seats about these shortcomings I think that they will get fixed sooner than later...
The free market can only function if all participants have full knowledge, right ?
Wink
Reply #11 - Jan 6th, 2009, 6:18am
I've no problem with honest and constructive negative comments about practical experience being posted in a public forum such as this - I'm all for realistic information about tools being shared, both good and bad.
That's not what I was saying. I was just suggesting that by also working with your EDA vendor, getting problems fixed is much more likely. What I'm saying is it's a good idea to light the fire underneath the EDA vendor's own seat, rather than under a seat in a public park, hoping that that EDA vendor just happens to be sitting on it at the time.
