May 2nd, 2024, 6:20am
Calibre PEX warnings WARNING: Could not find property ID for "sa". (Read 4465 times)
mvaibhav
Jan 13th, 2009, 7:20am
When I run Calibre PEX on my design in IBM process, it creates the Calibre view but gives warnings like:
"sa" is a property of the FETs used in the design. So, basically, it's not evaluating this parameter which is important for simulations. In the extracted netlist I see some default values of sa.
Can anyone tell me what's wrong?
Thanks.
vaibhav
oermens
Re: Calibre PEX warnings WARNING: Could not find property ID for "sa".
Reply #1 - Jan 18th, 2009, 9:12pm
if you're getting your kits/fab support through mosis then try asking on their message board: http://tech.groups.yahoo.com/group/MOSIS_Users_Group/
i've seen notices in my output log such as
   `sa1' is not specified. `sa' is used.
   `sb1' is not specified. `sb' is used.
but never thougth much of them. im working with ibm cmos8rf-dm 130nm kit btw
mvaibhav
Reply #2 - Jan 19th, 2009, 5:07am
I'm also using the same kit IBM 8RF-DM 130nm. In your case, at least it is using the property, in my case I think it's totally ignoring it. I ask Mosis support but they never encountered this problem. I'll try on Mosis yahoogroups.
Thanks.
vaibhav
oermens
Reply #3 - Jan 19th, 2009, 7:54am
What version of the kit are you using? Every time the admin updates the kit, the user has to do some changes to his/her .cdsinit, .cdsenv, .simrc, display.drf (or overwrite local copies with the ones in /<version>/IBM_PDK/cmrf8sf/<subversion>/cdslib/examples/). These files refer to full paths, even if you create the rel symbolic link. What I did is edit the files to point to rel so that I don't have to overwrite them everytime. If cadence is looking for files in different releases of the kit that might screw things up, so make sure everything is pointing to the latest version of your kit. Not sure if this will solve your problem, but its worth a shot.
