Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
May 2
nd
, 2024, 3:34pm
Home
Help
Search
Login
Register
PM to admin
Other CAD Tools
Physical Verification, Extraction and Analysis
› Loading dspf file into schematic?
Previous topic
Next topic
Loading dspf file into schematic? (Read 119 times)
Haydar
Portland, OR
Feb 09
th
, 2009, 5:26pm
Suppose I created independently a dspf file with mosfet AD,PD,AS,PS values. How can I load this dspf file into my schematic in Cadence?
-Haydar
IP Logged
bernd
Munich/Germany
Re: Loading dspf file into schematic?
Reply #1 -
Feb 10
th
, 2009, 1:03am
I think there is no official way of importing dspf as a schematic
in Cadence, one may have written some custom SKILL to do this.
But may I ask you what's the purpose of doing this?
* bernd
Just another lonesome cad guy
IP Logged
imd1
Reply #2 -
Feb 10
th
, 2009, 1:29am
Spicevision from Concept Engineering Gmbh should be able to do this. At least the demo I saw appeared to do that with dspf information.
Look at
http://www.concept.de/sv_index.html
I was looking at migrating schematics between tools (virtuoso to/from others) at the time, and we did not purchase it.
IP Logged
Haydar
Portland, OR
Reply #3 -
Feb 10
th
, 2009, 9:00am
The reason I asked this is because I have a separate tool which estimates pre-layout device parasitics. And I'd like to get this information into the Cadence flow prior to the Spectre simulation.
-Haydar
IP Logged
bernd
Munich/Germany
Reply #4 -
Feb 11
th
, 2009, 2:55am
Usually you use DSPF in a digital flow, with a static trimming analysis tool. In analog it's typically SPICE like file format with included
parasitics.
Especially if you want to simulate your parasitcs with Spectre you should look if your RC extraction tool may be able to create a so
called 'extracted view' in the Cadence DFII environment, this view then
can be easily plugged in for simulation.
If not SPICE is also a solution, but I guess you will struggle with
DSPF.
* bernd
IP Logged
Reply #5 -
Feb 12
th
, 2009, 1:25pm
Note that Ultrasim supports DSPF stitching - where you can "annotate" the DSPF parasitics onto the transistors in your schematic hierarchy prior to simulating it. There are menus on the ADE forms for Ultrasim which allow you to do this.
Spectre does not currently support DSPF (or SPEF) stitching.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
»» Physical Verification, Extraction and Analysis
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
