May 4th, 2024, 6:10am
Envelope Analysis is available in Cadence AMS ? (Read 4775 times)
Feb 14th, 2009, 5:28am
I have some questions about AMS simulation of Cadence.
Currently I can use Verilog-AMS models in cosimulation between Envelope Analysis of Agilent ADSsim and Cadence NCSim.
In next release Agilent GoldenGate, I can use Verilog-AMS models in cosimulation between Envelope Analysis of Agilent GoldenGate and Cadence NCSim.
Currently only Transient Analysis of GoldenGate is available in cosimulation with Cadence NCSim.
Of course, Verilog-A(MS) models which include hidden states in analog block can't be treated in Envelope Analysis of Agilent ADSsim and GoldenGate.
Instead I can use special behavioral models called FDD in Envelope Analysis of Agilent ADSsim.
(1) Envelope Analysis(both shooting and HB) of Cadence is available in AMS simulation ?
The Verilog-A models which include hidden states are refused in Envelope Analysis of Cadence Spectre.
(2) If there are hidden states in analog block of Verilog-AMS models, how to treat these hidden states in Cadence Envelope Analysis of AMS ?
« Last Edit: Feb 14th, 2009, 8:28pm by pancho_hideboo »
Re: Envelope Analysis is available in Cadence AMS ?
Reply #1 - Feb 15th, 2009, 2:16am
Self followup.
pancho_hideboo wrote on Feb 14th, 2009, 5:28am:
Spectre RF New Features in MMSIM 6.2
AMS and SpectreRF Envelope Analysis Co-Simulation
Spectre RF now supports co-simulation with AMS Designer for envelope analyses such as multi-carrier, autonomous, and FM modulation.
Is this for both shooting and HB ?
Reply #2 - Feb 15th, 2009, 5:26am
Yes, it supports both HB and Shooting. It's slightly misleading that it's mentioned in the MMSIM62 release notes, because the capability comes in the IUS stream - but the IUS stream based on MMSIM62 or later contains this, which means IUS611 or later, I think...
