May 11th, 2024, 3:47am
voltage limited current controlled current source (cccs) (Read 3136 times)
Ari
Israel
Feb 16th, 2009, 2:07pm
I wish to build voltage limited current controlled current source using Verilog A module, to model ideal current source which is limited to supply voltage when current sink has high resistivity.
I tried using the following code, but it fails to converge for high impedance load on Isink.
any ideas how to implement such a source?
 I(sink,src) <+ gain*I(ctrl_p,ctrl_n);
   if (V(src)>vclip) begin
      $strobe("cccs_vlimit clipping voltage as it is=:%g and clip value is:%g\n",V(sink,src),vclip);
      I(sink,src)<+ max(0, gain*I(ctrl_p,ctrl_n) + gm_nom*(V(src)-vclip));
   end //if
Peruzzi
Re: voltage limited current controlled current source (cccs)
Reply #1 - Feb 16th, 2009, 3:27pm
Ari,
Try combining with exponential functions for limiting.  It will be continuous in all its derivitives and will behave better.
Bob Peruzzi
