May 21st, 2024, 12:11pm
Pages: 1 2
pole zero doublet (Read 3465 times)
vivkr
Re: pole zero doublet
Reply #15 - Mar 20th, 2009, 12:40am
zzhang wrote on Mar 19th, 2009, 11:52pm:
i have design a gainboost amp, the main amp is telescopic and the aux amp is foled. the pole-zeros are all real number when the three amps simulated seperately. but when i simulted the gainboost one, the first two doublets which were arised by two aux ampa are complex numbers. I doubt how the complex numbers doublts arise,why they weren't the real numbers doublts.
What else do you expect? The auxiliary amps after all are now in closed-loop.
Vivek
Sarig
Reply #16 - Mar 20th, 2009, 5:20am
Simple answer:
when you start playing with tricks to fix your PM by adding zeros or compensation Ideas then problmes start and if yo usee that your phase is not acting like 1st / 2nd order but aslo rise sometimes then you got some doublet issue.
Erez
Manas
Bangalore,INDIA
Reply #17 - Feb 18th, 2010, 11:08pm
raja.cedt wrote on Mar 3rd, 2009, 10:23pm:
hi,
   i think it  is always better to check doublet effect in time response,because in ac simulation u may miss doublet if they are very close and if step is large of course with transient response also same will happen if we are not  care....
How you will see the doublet effect from the time response ??
View Profile Manas   IP Logged
Berti
Reply #18 - Feb 18th, 2010, 11:33pm
Manas, you will find the answer to your question in the following paper:
@article{KamathJSSCDec74,
B.Yeshwant Robert G.Meyer and Paul R. Gray
Relationship Between Frequency Response and Settling Time of Operational Amplifiers
IEEE of Solid--State Circuits
1974
volume = "sc-9",
number = "6",
month = "December",
pages = "347-352"
Pages: 1 2
