Jul 18th, 2024, 1:35am
Pages: 1 2 3
How to simulate this circuit in Spectre??? (Read 45108 times)
Yutao Liu
Guangzhou, China
Re: How to simulate this circuit in Spectre???
Reply #15 - Apr 29th, 2009, 1:10am
pancho_hideboo wrote on Apr 28th, 2009, 9:09pm:
Yutao Liu wrote on Apr 28th, 2009, 8:24pm:
attach is the netlists and the model of n18.
Both statements of parameter definition and statements of analysis don't exist. Angry
As I said to you repeatedly, no one except for you knows your specific situations.
What sizes on earth did you use as W and L for "n18" ? Angry
Show me complete netlists. e.g. "input.scs" if you use Cadence Spectre from ADE.
I am sorry for my mistake.  :-[
input.rar is the input.scs file for my simulation.
And "op2 .scs" file listed inside is used to store the operating points while sweeping vds.
There is only one statement in "op2.scs", which is "save NM1:oppoint".
I hope information attached this time would be complete.
best regards
subgold
Reply #16 - Apr 29th, 2009, 1:30am
Yutao Liu wrote on Apr 29th, 2009, 12:33am:
best regards
first thing to try, do not define w and l as variable. specify them directly in the transistor property in the schematic.
Reply #17 - Apr 29th, 2009, 1:38am
Yutao Liu wrote on Apr 29th, 2009, 1:10am:
Still there are some unknown parameters like followings.
Are they all zero ?
Quote:
run Yutao_Liu.scs
Yutao_Liu.log
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 6.2.0.493 -- 19 Sep 2007
Copyright (C) 1989-2007 Cadence Design Systems, Inc. All rights reserved
       worldwide. Cadence, Virtuoso and Spectre are registered trademarks of
       Cadence Design Systems, Inc. All others are the property of their
       respective holders.
Protected by U.S. Patents: 5,610,847; 5,790,436; 5,812,431; 5,859,785;
       5,949,992; 5,987,238; 6,088,523; 6,101,323; 6,151,698; 6,181,754;
       6,260,176; 6,278,964; 6,349,272; 6,374,390; 6,493,849; 6,504,885;
       6,618,837; 6,636,839; 6,778,025; 6,832,358; 6,851,097; 6,928,626;
       7,024,652; 7,035,782; 7,085,700; 7,143,021.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA
       Security, Inc.
Simulating `Yutao_Liu.scs' on lkenpc06 at 5:32:25 PM, Wed Apr 29, 2009.
Error found by spectre during hierarchy flattening.
   ERROR (SFE-1999): "./n18.scs" 3: model `n18': parameter `tox': Unknown
       parameter name `dtox_n18' found in expression.
   ERROR (SFE-1999): "./n18.scs" 3: model `n18': parameter `xl': Unknown
       parameter name `dxl_n18' found in expression.
   ERROR (SFE-1999): "./n18.scs" 3: model `n18': parameter `xw': Unknown
       parameter name `dxw_n18' found in expression.
   ERROR (SFE-1999): "./n18.scs" 3: model `n18': parameter `vth0': Unknown
       parameter name `dvth_n18' found in expression.
   ERROR (SFE-1999): "./n18.scs" 3: model `n18': parameter `pvth0': Unknown
       parameter name `dpvth0_n18' found in expression.
spectre terminated prematurely due to fatal error.
Yutao Liu
Guangzhou, China
Reply #18 - Apr 29th, 2009, 1:53am
subgold wrote on Apr 29th, 2009, 1:30am:
best regards
Thanks for subgold's suggestion.
I did this change before I change the w and l as variable. But the result did not change.
And when I run the simulation, the simulator warned me that  "Vgs has exceeded the oxide breakdown voltage"
Dose this warning matter? If so, how should I change my simulation?
Yutao Liu
Guangzhou, China
Reply #19 - Apr 29th, 2009, 2:07am
pancho_hideboo wrote on Apr 29th, 2009, 1:38am:
Are they all zero ?
Quote:
run Yutao_Liu.scs
Yutao_Liu.log
       respective holders.
       Security, Inc.
Oh, god! i forget to show you those datum again! Please forgive me!
Yes, those datum are all zero.
Please try this model file (attached) where all those datum have been set zero.
Thanks a lot.
Reply #20 - Apr 29th, 2009, 4:31am
Attached is a method I suggested in http://www.designers-guide.org/Forum/YaBB.pl?num=1240322183/4#4
Your NMOS FET is connected to nodes, "d", "g", "s" and "GND".
From practical point of view, a method subgold suggested is more good because input signals of OPAmp is very small in my method.
Indeed I don't use any of the followings.
  - Testbench which sheldon showed
  - my suggestion
  - subgold suggestion
I use Agilent ADSsim(RFDE) for device characterizations.
Here I invoke optimizer with parametric sweep.
[Parametric Sweep of vds]
    [Optimization of vgs for target Ids under vds]
      [Final Analysis such as DCOP, SP, AC, Noise under seached bias conditions, vgs, vds, Ids]
The followings are non parametric sweep case.
http://www.designers-guide.org/Forum/YaBB.pl?num=1212376329/3#3
http://www.designers-guide.org/Forum/YaBB.pl?num=1203057659/7#7
As you said to us, testbench which sheldon showed don't seem to work correctly.
Later I will investigate causes.
« Last Edit: Apr 29th, 2009, 7:11am by pancho_hideboo »
subgold
Reply #21 - Apr 29th, 2009, 6:36am
Yutao Liu wrote on Apr 29th, 2009, 1:53am:
best regards
i think the warning is exactly the problem. since your netlist looks fine, i think it is purely a simulator related problem, because everyting is ideal here, the cccs is also modeled as an ideal current source, which has very high impedance (seems to be 10^12ohm). therefore, with the current of the ideal current source, your gate voltage goes crazy and the correct dc operation points are never obtained.
try to clamp a diode there, with anode connected to the gate, and cathode connected to the max. allowed voltage (vdd), and see if it works.
Reply #22 - Apr 29th, 2009, 9:19pm
This is a method which subgold suggested. Here I used Cadence Spectre.
Reply #23 - Apr 29th, 2009, 10:07pm
This is a result of Agilent ADSsim.
Yutao Liu
Guangzhou, China
Reply #24 - Apr 30th, 2009, 1:46am
pancho_hideboo wrote on Apr 29th, 2009, 9:19pm:
Thanks for pancho_hideboo's reply.
The simulation results exactly meet what i want.
But I don't quite understand why the opamp in ahdlLib is able to achieve the result while the vcvs in analogLib fails, since both of them are used to make the drain voltage keep tracked with "Vds" while sweeping, and to stabilize the gate voltage?
What 's the difference between them?
Best regards!
Reply #25 - Apr 30th, 2009, 5:31am
Yutao,
  If you want measure gm, why don't you limit the sweep range
to bias conditions where the device is in saturation? You are forcing
the Vds to be perfectly 0, vds=0, at the same time you are forcing
the transistor to conduct a finite current, ibias=40u. This condition
is not physical so the model and the testbench react non-physically.
If you sweep the Vds from 3.2V to 0V, you will see that the Vgs
becomes large as the Vds approaches 0 and that the curve starts
to break up at about Vd,sat. The op-amp model clamps at the supply
voltage so that  the results look better. Also you will need to use
a different testbench to measure rds when Vds < Vds,sat.
Reply #26 - May 1st, 2009, 4:51am
A method which subgold suggested is unreasonable for low Vds region.
A method which my suggested is more reasonable for low Vds region.
 - my suggestion
Attached figure is an example I'm using for device characterization, here I use SP-Analysis as FinalAnalysis of Optimizer.
[Parametric Sweep of Idrain ; Sweep2]
  [Parametric Sweep of Vds ; Sweep1]
       [Optimization of Vgs for target Idrain under Vds ; Optim1 with DC1]
     [SP Analysis as Final Analysis under seached bias conditions, Vgs, Vds, Idrain ; SP1]
This result is also reasonable for low Vds region.
Reply #27 - May 1st, 2009, 6:12am
Yutao,
  I am curious about your original testbench. I was looking at the
EE240 website lecture on MOS transistors and found the references
on these pages. Was this your original testbench the circuit described
on page 14?
https://www.eecs.berkeley.edu/~boser/courses/240_2004_sp/index.html
Yutao Liu
Guangzhou, China
Reply #28 - May 1st, 2009, 6:47am
sheldon wrote on May 1st, 2009, 6:12am:
Yutao,
on page 14?
Sheldon,
Not on page 14, but on page 33 instead.  And my reference is http://bwrc.eecs.berkeley.edu/classes/icdesign/ee240_s09/lectures/Lecture04_MOS_... on page 10.
I used the vcvs as the feedback opamp in spectre, and I failed.
I think the testbench that pancho_hideboo provided is feasible and the result looks the same as that on the notes.
But I still don't understand what difference between opamp in ahdlLib and vcvs in analogLib makes the simulation result different, even if I read your reply. Could you explain more clearly, please?
        Best regards,
        Yutao
Yutao Liu
Guangzhou, China
Reply #29 - May 1st, 2009, 7:05am
Pancho_hideboo,
thanks for your work. I think your testbench is feasible and the result looks reliable.
I have tried your testbench in spectre, the result looks the same as yours basically, but discontinuity exist when vds is in low region, as shown below. My schematic and the setting of the opamp is totally the same as you described above. Do you have any idea what makes the discontinuity?
Thanks.
Best regards
yutao
Pages: 1 2 3
