May 4th, 2024, 6:09pm
Dynamic dac measurements (Read 4046 times)
jdac_18
Apr 23rd, 2009, 4:09am
I am testing a 10-bit segmented current steering dac, 4-binary, 6-thermometer.  I have tested the Static parameters and get an INL of 0.5LSB and DNL 0.4LSB with no filter.  Now I am testing the Dynamic parameters, and it seems pretty bad.  The initial specs were for the dac to sample at 800Msps up to about 1/2 the nyquist.  At 800Msps with a 10Mhz input sine, I can only an SFDR of 33dB. At higher input frequencies the SFDR goes down to below 10dB.  I also checked the output on an oscillascope and starting from about 50Mhz the output is not a good sine wave, and by 200 it resembles a pulse.  10Mhz sine has quite a bit of glitch.  Below is the screen shot.
Could it be a clock problem?  Jitter, crosstalk?
Or a design flaw.
Equipment:
Agilent PPG
Osc
voltage generator
Re: Dynamic dac measurements
Reply #1 - Jun 7th, 2009, 9:42pm
It looks like the design has some flaw. But what do you use to measure the dynamic performance?
