May 18th, 2024, 8:32pm
Cadence Noise-Aware PLL Design Flow (Read 2576 times)
jenand
Jun 07th, 2009, 5:34am
I am using the Cadence Noise-Aware PLL Design flow to speed up the simulation of my PLL designs. In Cadence version 6.x everything works great and there are no problems. Unfortunately, not all of my design kits (I'm working with three different technologies) support the new library format. In Cadence IC 5.1.41 I have the problem that the template does not provide a sweep for the tuning voltage. I can sweep both VDD and VSS, but there is no option to sweep Vtune. My configuration is IC 5.1.41 and MMSIM 7.0. Can anybody tell me if there is possibly something wrong with my setup or if there is a way to manually sweep Vtune and still have the oscillator model generated automatically?
Thanks in advance,
Jens
