May 18th, 2024, 10:05am
Help with resistive extraction in RCX (Read 2514 times)
mia
Jun 07th, 2009, 3:41pm
Dear All,
I'm trying to block the resistive parasitic extraction of some layers (in current case, poly) . I know that there is a command called res_blocking in the capgen options but I dont know how to use it.
I run Assura 3.1.6 RCX from the GUI. I tried editing the RCXspiceINIT file under Assura/LPE but couldnt succesfully block poly resistance from being extracted.
I'd appreciate any suggestions and help in this matter.
Thanks !
Re: Help with resistive extraction in RCX
Reply #1 - Jul 10th, 2009, 9:13am
Blocking layers need to be specified when you run capgen. For more details, read the extraction documentation...
Note that you're using an old (unsupported) version - probably wise to use something more recent.
